You can configure the translation role for an NSSA to ensure that Type-7 LSAs are always translated into Type-5 LSAs. Alternatively, the default setting simply identifies an NSSA border router as a candidate that can participate in the translator election process.
This example configures area 0.0.0.6 as an NSSA in SEFOS1 (router ID 10.0.0.1) and specifies that the border router will always be able to translate Type-7 LSAs into Type-5 LSAs.
SEFOS# configure terminal
SEFOS(config)# ipv6 router ospf
SEFOS(config-router)# router-id 10.0.0.1
SEFOS(config-router)# asbr router
SEFOS(config-router)# area 0.0.0.6 nssa
SEFOS(config-router)# area 0.0.0.6 translation-role always
SEFOS# show ipv6 ospf areas OSPFV3 AREA CONFIGURATION INFORMATION AreaId: 0.0.0.0 Area Type: NORMAL AREA Spf Calculation: 13 (times) Area Bdr Rtr Count: 0 As Bdr Rtr Count: 0 Area Summary: Send Summary AreaId: 0.0.0.6 Area Type: NSS AREA Spf Calculation: 13 (times) Area Bdr Rtr Count: 0 As Bdr Rtr Count: 0 Area Summary: Send Summary Stub Metric: 0x1 Stub Metric Type: 2 Translator Role: Always Translator State: Elected/Enabled Nssa Stability Interval: 40
