If default summary routes are selected, you can configure the metric type for the default summary route that is sent to an NSSA.
This example configures the IP address 0.0.0.6 as an NSSA in SEFOS1 (router ID 10.0.0.1) and specifies that the metric type for the NSSA is Type-2 external cost (value 3).
SEFOS# configure terminal
SEFOS(config)# ipv6 router ospf
SEFOS(config-router)# router-id 10.0.0.1
SEFOS(config-router)# area 0.0.0.6 nssa
SEFOS(config-router)# area 0.0.0.6 default-metric type 3 SEFOS(config-router)# exit
SEFOS# show ipv6 ospf areas OSPFV3 AREA CONFIGURATION INFORMATION AreaId: 0.0.0.0 Area Type: NORMAL AREA Spf Calculation: 14 (times) Area Bdr Rtr Count: 0 As Bdr Rtr Count: 0 Area Summary: Send Summary AreaId: 0.0.0.6 Area Type: NSS AREA Spf Calculation: 14 (times) Area Bdr Rtr Count: 0 As Bdr Rtr Count: 0 Area Summary: Send Summary Stub Metric: 0x1 Stub Metric Type: 3 Translator Role: Candidate Translator State: Elected/Enabled Nssa Stability Interval: 40
