You can specify the OSPF network type to be broadcast, non-broadcast, point-to-multipoint, or point-to-point. The default value is broadcast. The OSPF network type can be configured to a type other than the default for a given media.
This example configures the network type for VLAN 10 as point-to-point, meaning that it is a network that joins a single pair of routers.
SEFOS(config)# interface vlan 10 SEFOS(config-if)# ipv6 ospf network point-to-point SEFOS(config-if)# end
SEFOS# show ipv6 ospf interface vlan 10
Ospfv3 Interface Information
Interface Name: vlan10 Interface Id: 41 Area Id: 0.0.0.6
Local Address: fe80::214:4fff:fe6c:628f Router Id: 10.0.0.1
Network Type: PTOP Cost: 1 State: PTOP
Designated Router Id: 0.0.0.0 local address: (null)
Backup Designated Router Id: 0.0.0.0 local address: (null)
Transmit Delay: 1 sec Priority: 1 IfOptions: 0x0
Timer intervals configured:
Hello: 10, Dead: 40, Retransmit: 5, Poll: 120
Demand Circuit: Disable Neighbor Probing: Disable
Nbr Probe Retrans Limit: 10 Nbr Probe Interval: 120
Hello due in 4 sec
Neighbor Count is: 0
