Routers that act as gateways (redistribution) between OSPF and other routing protocols (IGRP, EIGRP, RIP, BGP, static) or other instances of the OSPF routing process, are called ASBRs. An ASBR must be enabled for routes to be redistributed from other protocols.
This example configures router 10.0.0.1 to act as an ASBR.
SEFOS(config)# ipv6 router ospf SEFOS(config-router)# asbr router SEFOS(config-router)# end
SEFOS# show ipv6 ospf
Router Id: 10.0.0.1 ABR Type: Standard ABR
SPF schedule delay: 5 secs Hold time between two SPFs: 10 secs
Exit Overflow Interval: 0 Ref BW: 100000 Ext Lsdb Limit: -1
Trace Value: 0x00000800 As Scope Lsa: 0 Checksum Sum: 0x0
Demand Circuit: Enable Passive Interface: Disable
Nssa Asbr Default Route Translation: Disable
It is an Area Border Router
Autonomous System Boundary Router
Number of Areas in this router 2
Area 0.0.0.0
Number of interfaces in this area is 1
Number of Area Scope Lsa: 5 Checksum Sum: 0x2caf7
Number of Indication Lsa: 0 SPF algorithm executed: 7 times
Area 0.0.0.6
Number of Area Scope Lsa: 5 Checksum Sum: 0x3507d
