Restore the Default External
Database Limit
This example restores the default external database
limit to -1 (no limit) for SEFOS1 (router 10.0.0.1).
Note - The exit overflow interval will be 0 until you configure
it.
- Enter
Global Configuration mode in SEFOS1.
SEFOS# configure terminal
- Enable OSPF globally in the switch
SEFOS1.
SEFOS(config)# ipv6 router ospf
- Configure the OSPF router ID.
SEFOS(config-router)# router-id 10.0.0.1
- Configure the external LSDB limit.
SEFOS(config-router)# as-external lsdb-limit -1
- Exit Router Configuration mode.
SEFOS(config-router)# end
