See NSSA Type-7/-5 Conversion Topology for the NSSA Type-7/-5 conversion topology created in this example.
SEFOS(config)# ipv6 router ospf SEFOS(config-router)# router-id 10.0.0.9 SEFOS(config-router)# ASBR Router SEFOS(config-router)# redistribute static SEFOS(config-router)# exit SEFOS(config)# interface vlan 2 SEFOS(config-if)# ipv6 ospf area 0.0.0.2 SEFOS(config-if)# exit
SEFOS(config)# ipv6 router ospf SEFOS(config-router)# area 0.0.0.2 nssa SEFOS(config-router)# end
SEFOS(config)# ipv6 router ospf SEFOS(config-router)# router-id 10.0.0.2 SEFOS(config-router)# exit SEFOS(config)# interface vlan 2 SEFOS(config-if)# ipv6 ospf area 0.0.0.2 SEFOS(config-if)# exit SEFOS(config)# interface vlan 11 SEFOS(config-if)# ipv6 ospf area 0.0.0.0 SEFOS(config-if)# exit
SEFOS(config)# ipv6 router ospf SEFOS(config-router)# area 0.0.0.2 nssa SEFOS(config-router)# exit
SEFOS(config)# ipv6 router ospf SEFOS(config-router)# router-id 10.0.0.1 SEFOS(config-router)# exit SEFOS(config)# interface vlan 11 SEFOS(config-if)# ipv6 ospf area 0.0.0.0 SEFOS(config-if)# exit SEFOS(config)# ipv6 router ospf SEFOS(config-router)# end
Add a static route to 4444::/96 through VLAN 1, where the IPv6 address for VLAN 1 on SEFOS9 is 3333::2222:0:1/96, with a next hop of 3333::2222:0:10/96.
SEFOS(config)# ipv6 route 4444:: 96 3333::2222:0:10 SEFOS(config)# exit
In SEFOS9, type.
SEFOS# show ipv6 ospf database nssa detail Age: 42 Seconds LS Type: Type-7 Lsa Link State Id: 0.0.0.0 Adv Rtr Id: 10.0.0.2 Sequence: 0x80000002 Checksum: 0x0d20 Length: 28 Metric: 0x1 Metric Type: Ext Type1 Prefix Length: 0 Prefix Options: 0x00 Referenced LS Type: 0 Address Prefix: ::10:10f8:5830:300:e450 Fw Address Prefix: 3ddf:c7e8:3ddf:c738:ff4:324:3d50:10 External Route Tag: 0 Age: 0 Seconds LS Type: Type-7 Lsa Link State Id: 0.0.0.1 Adv Rtr Id: 10.0.0.9 Sequence: 0x80000001 Checksum: 0xe6e5 Length: 56 Metric: 0xa Metric Type: Ext Type2 Prefix Length: 96 Prefix Options: 0x08 Referenced LS Type: 0 Address Prefix: 4444::300:e450
In SEFOS2, type.
SEFOS# show ipv6 ospf database nssa detail Age: 0 Seconds LS Type: Type-7 Lsa Link State Id: 0.0.0.0 Adv Rtr Id: 10.0.0.2 Sequence: 0x80000002 Checksum: 0x0d20 Length: 28 Metric: 0x1 Metric Type: Ext Type1 Prefix Length: 0 Prefix Options: 0x00 Referenced LS Type: 0 Address Prefix: ::10:10f8:5920:300:2450 Fw Address Prefix: 3621:828:3621:778:ff4:324:fe4:2988 External Route Tag: 0 Age: 3 Seconds LS Type: Type-7 Lsa Link State Id: 0.0.0.1 Adv Rtr Id: 10.0.0.9 Sequence: 0x80000001 Checksum: 0xe6e5 Length: 56 Metric: 0xa Metric Type: Ext Type2 Prefix Length: 96 Prefix Options: 0x08 Referenced LS Type: 0 Address Prefix: 4444::300:2450
In SEFOS1, type.
SEFOS# show ipv6 ospf database as-external detail Age: 3 Seconds LS Type: External Lsa Link State Id: 0.0.0.1 Adv Rtr Id: 10.0.0.2 Sequence: 0x80000001 Checksum: 0x0bb2 Length: 56 Metric Type: Ext Type2 Metric: 0xa Prefix Length: 96 Prefix Options: 0x00 Referenced LS Type: 0 Addres Prefix: 4444:: Fw Addres Prefix: 4444::fec0:0 External Route Tag: 0
SEFOS(config)# ipv6 router ospf SEFOS(config-router)# no nssaAsbrDfRtTrans
SEFOS(config-router)# area 0.0.0.0 summary-prefix 4444::64 translation disabled SEFOS(config-router)# exit
