Exit Print View
This section describes various options you can configure when configuring an NSSA.
You can configure area parameters only after enabling the OSPF process. Configure these parameters in Router Configuration mode.
Configure the Stability Interval for NSSA
Restore the Default Stability Interval
Configure an NSSA Translation Role
Restore the Default Translation Role
Configure Default Summary Route for an NSSA
Configure the Metric Type for an NSSA
