The stability interval is used when an elected translator determines that its services are no longer required and the translator continues its translation duties for additional time.
This example configures area 0.0.0.6 to be an NSSA with the stability interval set to 120 seconds.
SEFOS# configure terminal
SEFOS(config)# ipv6 router ospf
SEFOS(config-router)# router-id 10.0.0.1
SEFOS(config-router)# asbr router
SEFOS(config-router)# area 0.0.0.6 nssa
SEFOS(config-router)# area 0.0.0.6 stability-interval 120
SEFOS# show ipv6 ospf areas OSPFV3 AREA CONFIGURATION INFORMATION AreaId: 0.0.0.0 Area Type: NORMAL AREA Spf Calculation: 12 (times) Area Bdr Rtr Count: 0 As Bdr Rtr Count: 0 Area Summary: Send Summary AreaId: 0.0.0.6 Area Type: NSS AREA Spf Calculation: 12 (times) Area Bdr Rtr Count: 0 As Bdr Rtr Count: 0 Area Summary: Send Summary Stub Metric: 0x1 Stub Metric Type: 2 Translator Role: Candidate Translator State: Elected/Enabled Nssa Stability Interval: 120
