Configure the Name of the Configuration
File
This task describes how to write the configuration
file to flash. This file is used as the restoration configuration
file.
- Connect
to SEFOS.
See Connect to SEFOS.
- Configure the configuration file
name.
- Enter Global Configuration
mode.
SEFOS-1# configure terminal
- Configure the restoration configuration
file name for the switch.
For example:
SEFOS-1(config)# default restore-file myconfig.conf
- Exit Global Configuration mode.
SEFOS-1(config)# end
- View the default configuration
file name.
SEFOS-1# show nvram
Config Restore Filename : myconfig.conf
