This task describes how to clear the contents of the startup configuration or set the parameters in flash to their default values.
See Connect to SEFOS.
SEFOS-1# erase startup-config
SEFOS-1# show nvram ... Config Restore Option : No restore Config Save Option : No save Auto Save : Disable ... Config Save Filename : switch.conf Config Restore Filename : switch.conf ...
The switch starts with the default configurations when you reboot the switch.
