If you leave a session idle for too long, the session might get disconnected and return you to the Oracle ILOM prompt. This task clears the timeout for line connections so that idle sessions are not disconnected.
See Connect to SEFOS.
SEFOS-1# configure terminal
SEFOS-1(config)# line vty SEFOS-1(config-line)# no exec-timeout SEFOS-1(config-line)# exit
