oracle home
Oracle
Switch ES2-72 and Oracle Switch ES2-64 Configuration Guide
Exit Print View
Search Term
Search Scope:
This Document
Entire Library
Documentation Home
Oracle Switch ES2-72 and Oracle Switch ES2-64 ...
Oracle
Switch ES2-72 and ...
Configuring the Switching Feature
Switching Feature Topology
Updated: April 2015
Oracle
Document Information
Using This Documention
Product Documentation Library
Feedback
Administering the Switch
Oracle ILOM Overview
Connect to the Serial Console for Initial Configuration
Configure Network Management on the SP
Configure the Host Network Management From the CLI
Configure Other Network Settings (Oracle ILOM Web Interface)
Stopping, Starting, and Restarting the Host
Stop the Host
Start the Host
Restart the Host
Log Out of the Oracle ILOM CLI
Administering SEFOS
SEFOS Setup Tasks
Understanding SEFOS Basics
Basic SEFOS Topology
Port Terminology
Connect to SEFOS
Disconnect From SEFOS
Stop and Start SEFOS
Create a Local User
Change a SEFOS User Privilege Level
Configuring the SEFOS Environment
Enable or Disable the Timeout for Line Connections
Configure the IP Address for an Interface
Configure the Name of the Configuration File
Configure the Default VLAN ID
Enable or Disable Trap Generation on an Interface
Configure Debug Logging
Configure ACL Filters
Configure QoS
Configure Port Mirroring
Configure Rate Limiting
Configuring Save Parameters
Enable or Disable the Incremental Save Flag
Enable or Disable the Auto Save Flag
Managing Configuration Files
Save the Configuration to a File
Erase a Configuration File
Copy a Configuration File to a Remote Location
Copy a Configuration File From a Remote Location to Flash
Copy a Configuration File From One Remote Location or Flash to Another Remote Location or Flash
Managing Log Files
Copy a System Log to a Remote Location
View Debug Logs
Port Terminology
Configure Initial Settings
Verify the Configuration
Configure VLAN Forwarding
Verify VLAN Membership
Configure RSTP
Configure LA
Configuring the Routing Feature
Routing Feature Topology
Configuring Static Routing
Configure Static Unicast Route Entries
Add Static Routes
Configuring Dynamic Routing
Configure RIP Dynamic Routing
Configure OSPF Dynamic Routing
Disabling Routing
Remove Static Routes
Disable RIP Dynamic Routing
Disable OSPF Dynamic Routing
Glossary
Index
Index A
Index C
Index D
Index E
Index I
Index L
Index M
Index O
Index P
Index Q
Index R
Index S
Index T
Index U
Index V
Language:
English
Note -
All ports in this topology are in VLAN 101.
Related Information
Configure RSTP
Configure LA
Previous
Next
