- In
a web browser's location bar, type the IP address of the SP as configured earlier.
See Configure Network Management on the SP.
The switch Oracle ILOM login screen appears. The default user
name is root. The default password is changeme.
- Select Configuration from the
first row of tabs.
- Select Network from the second
row of tabs.
The Network Settings page for the switch appears.
- Configure the network settings
as desired.
- Click Save.
Note - When you click Save, connections to the web interface
might be lost. You must reestablish connection to the web interface.
