This task shows the traffic flow in the RSTP configuration on SEFOS running on the switch targets. This task verifies whether a loop is present in the topology, if it is detected, and if the traffic is blocked for the alternate port.
See Switching Feature Topology for the topology of this task.
SEFOS-1# show spanning-tree Root Id Priority 32768 Address 00:14:4f:6c:63:0f Cost 0 Port 0 [0] Max Age 20 Sec, Forward Delay 15 Sec Spanning tree Protocol Enabled. Bridge is executing the rstp compatible Rapid Spanning Tree Protocol Bridge Id Priority 32768 Address 00:14:4f:6c:63:0f Cost 0 Port 0 [0] Max Age 20 Sec, Forward Delay 15 Sec Spanning tree Protocol Enabled. Bridge is executing the rstp compatible Rapid Spanning Tree Protocol Bridge Id Priority 32768 Address 00:14:4f:6c:63:0f Hello Time 2 sec, Max Age 20 sec, Forward Delay 15 sec Dynamic Path Cost is Disabled Dynamic Path Cost Lag-Speed Change is Disabled Name Role State Cost Prio Type ---- ---- ----- ---- ---- ---- X10/1 Designated Forwarding 2000 128 P2P X10/2 Designated Forwarding 2000 128 P2P X10/21 Designated Forwarding 2000 128 P2P X10/22 Designated Forwarding 2000 128 P2P ...
SEFOS-2# show spanning-tree Root Id Priority 32768 Address 00:14:4f:6c:63:0f Cost 4000 Port X10/1 Max Age 20 Sec, Forward Delay 15 Sec Spanning tree Protocol Enabled. Bridge is executing the rstp compatible Rapid Spanning Tree Protocol Bridge Id Priority 32768 Address 00:14:4f:6c:6e:0e Hello Time 2 sec, Max Age 20 sec, Forward Delay 15 sec Dynamic Path Cost is Disabled Dynamic Path Cost Lag-Speed Change is Disabled Name Role State Cost Prio Type ---- ---- ----- ---- ---- ------ X10/1 Designated Forwarding 2000 128 P2P X10/21 root Forwarding 2000 128 P2P X10/22 Alternate Discarding 2000 128 P2P ...
# ping -s 20.0.0.30
Traffic is forwarded through the xl-ethernet 0/21 port on SEFOS-1 to SEFOS-2 port 21.
SEFOS-2# configure terminal SEFOS-2(config)# int xl 0/1 SEFOS-2(config)# shut SEFOS-2(config)# exit SEFOS-2# show spanning-tree Root Id Priority 32768 Address 00:14:4f:6c:69:0f Cost 4000 Port Xl0/2 Max Age 20 Sec, Forward Delay 15 Sec Spanning tree Protocol Enabled. Bridge is executing the rstp compatible Rapid Spanning Tree Protocol Bridge Id Priority 32768 Address 00:14:4f:6c:6e:0e Hello Time 2 sec, Max Age 20 sec, Forward Delay 15 sec Dynamic Path Cost is Disabled Dynamic Path Cost Lag-Speed Change is Disabled Name Role State Cost Prio Type ---- ---- ----- ---- ---- ------ Xl0/2 root Forwarding 2000 128 P2P Xl0/25 root Forwarding 2000 128 P2P Xl0/25 root Forwarding 2000 128 P2P ...
# ping 20.0.0.30
Traffic should be forwarded through the xl-ethernet 0/2 port on SEFOS-1. If RSTP is working, there will be a change in the port state.
