Once the network configuration is done on the SP (Configure Network Management on the SP), it can be accessed via ssh. Host configuration can be done by logging into the SP's serial console or by ssh.
# ssh root@10.134.178.170 Password: changeme Oracle(R) Integrated Lights Out Manager Version 3.2.5.60 r98416 Copyright (c) 2015, Oracle and/or its affiliates. All rights reserved. Warning: password is set to factory default. Warning: HTTPS certificate is set to factory default. Hostname: ES2-72-swi-sp ->
-> start /SYS Are you sure you want to start /SYS (y/n)? y Starting /SYS -> start /HOST/console Are you sure you want to start /HOST/console (y/n)? y
The switch host's Oracle ILOM login prompt appears.
The default user is root. The default password is changeme.
The switch Oracle ILOM login prompt appears.
Detecting screen size; please wait...done Oracle(R) Integrated Lights Out Manager Version xxxxxxx Copyright (c) 2015, Oracle and/or its affiliates. All rights reserved. ... Hostname: ES2-72-primary ES2->
ES2-> cd /SP/network/ /SP/network ES2-> show /SP/network Targets: ipv6 test Properties: commitpending = (Cannot show property) dhcp_clientid = none dhcp_server_ip = 10.134.178.5 ipaddress = 10.134.178.167 ipdiscovery = dhcp ipgateway = 10.134.178.1 ipnetmask = 255.255.255.0 macaddress = 00:19:0F:16:D4:19 pendingipaddress = 10.134.178.167 pendingipdiscovery = dhcp pendingipgateway = 10.134.178.1 pendingipnetmask = 255.255.255.0 state = enabled vlan_id = (none) Commands: cd set show
dhcp is enabled by default, so the host can get the network configuration automatically if there is a dhcp server on the network.
The names and addresses in the following examples are only for demonstration.
ES2-> set pendingipaddress=10.134.178.167 Set 'pendingipaddress' to '10.134.178.167' ES2-> set pendingipnetmask=255.255.255.0 Set 'pendingipnetmask' to '255.255.255.0' ES2-> set pendingipgateway=10.134.178.1 Set 'pendingipgateway' to '10.134.178.1' ES2-> set pendingipdiscovery=static Set 'pendingipdiscovery' to 'static' ES2-> set commitpending=true Set 'commitpending' to 'true' ES2-> show /SP/network Targets: ipv6 test Properties: commitpending = (Cannot show property) dhcp_clientid = none dhcp_server_ip = none ipaddress = 10.134.178.170 ipdiscovery = static ipgateway = 10.134.178.1 ipnetmask = 255.255.255.0 macaddress = 00:21:28:79:8B:58 pendingipaddress = 10.134.178.170 pendingipdiscovery = static pendingipgateway = 10.134.178.1 pendingipnetmask = 255.255.255.0 pendingvlan_id = (none) state = enabled vlan_id = (none
