Depending on how each server configures routes, you might need to add static routes with commands provided by the servers.
# route add 40.0.0.0 -netmask 255.255.255.0 10.0.0.201 # route add 20.0.0.0 -netmask 255.255.255.0 10.0.0.201
# route add -net 10.0.0.0 netmask 255.255.255.0 gw 40.0.0.200 # route add -net 20.0.0.0 netmask 255.255.255.0 gw 40.0.0.200
See Connect to SEFOS.
SEFOS-1# ping 40.0.0.200
SEFOS-1# ping 40.0.0.110
# ping -s 40.0.0.110
SEFOS-2# ping 10.0.0.201
SEFOS-2# ping 10.0.0.169
# ping 10.0.0.169
To reach host A from host B, packets must be routed between VLAN 40–VLAN 20 and VLAN 20–VLAN 10. With static routes configured, you can now test the routing functions with SEFOS.
