This task describes how to write the system logs to a remote location. The remote location must be a host on one of the 72 or 64 ports on the switch.
In this task, you first execute several commands to customize system logs. You also clear the system buffers so that the log file can be copied over to the remote site.
See Connect to SEFOS.
SEFOS# debug npapi transmission SEFOS# show debug-logging ... SEFOS# configure terminal SEFOS(config)# clear logs SEFOS(config)# end SEFOS# SEFOS-1# copy logs tftp://12.0.0.100/logfile % Log Upload Successful SEFOS# SEFOS# no debug npapi transmission SEFOS# SEFOS# show debugging
