This task describes how to configure and test the VLAN forwarding feature of SEFOS running on a switch target. This task tests whether the incoming packets are properly switched on the member ports of the VLAN.
See Switching Feature Topology for the topology of this task.
See Connect to SEFOS.
SEFOS-1# configure terminal SEFOS-1(config)# vlan 101 SEFOS-1(config-vlan)# ports xl-ethernet 0/1-2,0/25-26 untagged xl-ethernet 0/1-2,0/25-26 SEFOS-1(config-vlan)# vlan active SEFOS-1(config-vlan)# exit
