This task tests whether the incoming packets are properly switched on the member ports of the VLAN.
See Connect to SEFOS.
SEFOS-1# show vlan Vlan database ------------- Vlan ID : 101 Member Ports : X10/1,X10/2,X10/21,X10/22 Untagged Ports : X10/1,X10/2,X10/21,X10/22 Forbidden Ports : None Reflective-Relay : Disabled Name : Status : Other
# ping -s 20.0.0.20
# ping 20.0.0.10
SEFOS-2# configure terminal SEFOS-2(config)# vlan 101 SEFOS-1(config-vlan)# ports xl-ethernet 0/25,0/1-2 untagged xl-ethernet 0/25,0/1-2
SEFOS-2# config terminal SEFOS-2(config)# interface xl-ethernet 0/25 SEFOS-2(config-if)# no shutdown SEFOS-2(config-if)# end
SEFOS-2# show vlan Vlan database ------------- Vlan ID : 101 Member Ports : X10/1,X10/21, X10/22 Untagged Ports : X10/1,X10/21, X10/22 Forbidden Ports : None Reflective-Relay : Disabled Name : Status : Other
The ping should be successful.
# ping -s 20.0.0.20 # ping -s 20.0.0.30
