This task describes how to configure and test the LA feature of SEFOS running on a switch target.
See Switching Feature Topology for the topology of this task.
SEFOS-1# configure terminal SEFOS-1(config)# set port-channel enable SEFOS-1(config)# interface port-channel 100 SEFOS-1(config-if)# no shutdown SEFOS-1(config-if)# exit SEFOS-1(config)# interface range xl-ethernet 0/1-2 SEFOS-1(config-if)# no shutdown SEFOS-1(config-if)# channel-group 100 mode active SEFOS-1(config-if)# exit SEFOS-1(config)# vlan 101 SEFOS-1(config-vlan)# ports xl-ethernet 0/1-2 port-channel SEFOS-1(config-vlan)# ports xl-ethernet 0/25-26 port-channel 100 untagged xl-ethernet 0/25-26 port-channel 100
SEFOS-1# show vlan Vlan database ------------- Vlan ID : 101 Member Ports : X10/25,X10/26,po100 Untagged Ports : X10/25,X10/26,po100 Forbidden Ports : None Reflective-Relay : Disabled Name : Status : Other
SEFOS-1# show spanning-tree Root Id Priority 32768 Address 00:14:4f:6c:69:ee Cost 0 Port 0 [0] Max age 20 Sec, forward delay 15 Sec Hello Time 2 Sec MST00 Spanning tree Protocol has been enabled MST00 is executing the mstp compatible Multiple Spanning Tree Protocol Bridge Id Priority 32768 Address 00:14:4f:6c:69:ee Max age is 20 sec, forward delay is 15 sec Hello Time is 2 sec Dynamic Path Cost is Disabled Dynamic Path Cost Lag-Speed Change is Disabled Name Role State Cost Prio Type ---- ---- ----- ---- ---- ------ X10/25 Designated Forwarding 2000 128 P2P X10/26 Designated Forwarding 2000 128 P2P po100 Designated Forwarding 2000 128 P2P ...
There should not be any data loss during traffic forwarding.
SEFOS-1# show etherchannel summary Port-channel Module Admin Status is enabled Port-channel Module Oper Status is enabled Port-channel System Identifier is 00:14:4f:6c:69:ee Flags: D - down P - in port-channel I - stand-alone H - Hot-standby (LACP only) AD - Admin Down AU - Admin Up OD - Operative Down OU - Operative Up Number of channel-groups in use: 1 Number of aggregators: 1 Group Port-channel Protocol Ports ------------------------------------------------------------------------- 100 Po100(P)[AU,OD] LACP X10/1(P),X10/2(P) ...
SEFOS-1# configure terminal SEFOS-1(config)# int xl 0/1 SEFOS-1(config-if)# shut SEFOS-1(config-if)# end SEFOS-1# show etherchannel summary Port-channel Module Admin Status is enabled Port-channel Module Oper Status is enabled Port-channel System Identifier is 00:14:4f:6c:69:ee Flags: D - down P - in port-channel I - stand-alone H - Hot-standby (LACP only) AD - Admin Down AU - Admin Up OD - Operative Down OU - Operative Up Number of channel-groups in use: 1 Number of aggregators: 1 Group Port-channel Protocol Ports ----------------------------------------------------------------- 100 Po100(P)[AU,OD] LACP X10/1(D),X10/2(P) ...
LA was configured properly if traffic flows through the port channel group.
