This task configures dynamic routing with the redistribution feature of RIP in SEFOS. This task also verifies the accessibility of the two hosts by learning the routes dynamically through RIP.
See Routing Feature Topology for the topology of this task.
See Configure Static Unicast Route Entries.
The basic VLAN configuration for dynamic routing is similar to the basic VLAN configuration for static routing. If the configuration information was not saved on SEFOS-1 and SEFOS-2, follow Step 1 through Step 6 in Configure Static Unicast Route Entries, then return here.
SEFOS-1# configure terminal SEFOS-1(config)# router rip SEFOS-1(config-router)# neighbor 20.0.0.200 SEFOS-1(config-router)# network 20.0.0.201 SEFOS-1(config-router)# network 10.0.0.201 SEFOS-1(config-router)# redistribute all SEFOS-1(config-router)# end
SEFOS-2# configure terminal SEFOS-2(config)# router rip SEFOS-2(config-router)# neighbor 20.0.0.201 SEFOS-2(config-router)# network 20.0.0.200 SEFOS-2(config-router)# network 40.0.0.200 SEFOS-2(config-router)# redistribute all SEFOS-2(config-router)# end
If SEFOS-2 is a third-party switch, verify that the RIP is enabled on SEFOS-2 and that related configurations are applied accordingly.
SEFOS-1# show ip rip database Vrf default 10.0.0.0/8 [1] auto-summary 10.0.0.0/24 [1] directly connected, vlan10 20.0.0.0/8 [1] auto-summary 20.0.0.0/24 [1] directly connected, vlan20 40.0.0.0/8 [2] auto-summary 40.0.0.0/8 [2] via 20.0.0.200, vlan20
SEFOS-2# show ip rip database Vrf default 10.0.0.0/8 [2] auto-summary 10.0.0.0/8 [2] via 20.0.0.201, vlan20 20.0.0.0/8 [1] auto-summary 20.0.0.0/24 [1] directly connected, vlan20 40.0.0.0/8 [1] auto-summary 40.0.0.0/24 [1] directly connected, vlan40
# ping 10.0.0.201
# ping 10.0.0.169
# ping 40.0.0.110
You can test the basic routing features of SEFOS now that SEFOS is able to dynamically learn the routing entries using the redistribution feature of RIP.
