dhcp is enabled by default, so the SP can get the network configuration automatically if there is a DHCP server on the network.
The names and addresses in the following examples are only for demonstration.
ORACLESP-AKCH444444 login: root Password: changeme Detecting screen size; please wait...done Oracle(R) Integrated Lights Out Manager Version 3.2.5.60 r98416 Copyright (c) 2015, Oracle and/or its affiliates. All rights reserved. Warning: password is set to factory default. Warning: HTTPS certificate is set to factory default. Hostname: ORACLESP-AKCH444444 ->
-> cd /SP/network /SP/network -> show /SP/network Targets: ipv6 test Properties: commitpending = (Cannot show property) dhcp_clientid = none dhcp_server_ip = 10.134.178.5 ipaddress = 10.134.178.170 ipdiscovery = dhcp <--------- ipgateway = 10.134.178.1 ipnetmask = 255.255.255.0 macaddress = 00:21:28:79:8B:58 pendingipaddress = 10.134.178.170 pendingipdiscovery = dhcp pendingipgateway = 10.134.178.1 pendingipnetmask = 255.255.255.0 pendingvlan_id = (none) state = enabled vlan_id = (none) Commands: cd set show
-> set pendingipaddress=10.134.178.170 Set 'pendingipaddress' to '10.134.178.170' -> set pendingipnetmask=255.255.255.0 Set 'pendingipnetmask' to '255.255.255.0' -> set pendingipgateway=10.134.178.1 Set 'pendingipgateway' to '10.134.178.1' -> set pendingipdiscovery=static Set 'pendingipdiscovery' to 'static' -> set commitpending=true Set 'commitpending' to 'true' -> show /SP/network Targets: ipv6 test Properties: commitpending = (Cannot show property) dhcp_clientid = none dhcp_server_ip = none ipaddress = 10.134.178.170 ipdiscovery = static <--------- ipgateway = 10.134.178.1 ipnetmask = 255.255.255.0 macaddress = 00:21:28:79:8B:58 pendingipaddress = 10.134.178.170 pendingipdiscovery = static pendingipgateway = 10.134.178.1 pendingipnetmask = 255.255.255.0 pendingvlan_id = (none) state = enabled vlan_id = (none
-> set /SP/ hostname=ES2-72-swi-sp Set 'hostname' to 'ES2-72-swi-sp'
Once the network configuration is done on the SP, it can be accessed and modified via ssh.
