The fan modules are keyed to ensure that they are installed in the correct orientation.
See Troubleshooting Using the Server Front and Rear Panel Status Indicators for more information about identifying and interpreting system indicators.
If you installed the fan module as part of another procedure, return to that procedure.
Otherwise, return the server to operation. See Returning the Server to Operation.
