Go to main content
Oracle® Server X6-2 Service Manual
Exit Print View
Updated: January 2021
Servicing the Motherboard (FRU)
Follow these procedures to remove and install the motherboard.
Caution
Caution  - The motherboard should be serviced only by an Oracle qualified service technician.
Caution
Caution  - Ensure that all power is removed from the server before removing or installing the motherboard. You must disconnect the power cables before performing these procedures.
Caution
Caution  - These procedures require that you handle components that are sensitive to electrostatic discharge. This sensitivity can cause the components to fail. To avoid damage, ensure that you follow antistatic practices as described in Take Antistatic Measures.
Related Information
