Reinstall the Server Into the Rack
If you removed
the server chassis from the rack, perform these steps to reinstall
it.
 | Caution - Deploy any rack anti-tilt
mechanisms before installing the server into the rack. |
 | Caution -
The server weighs approximately 18.1 kg (40.0 lbs). Two people are required to carry the
chassis and install it into the rack.
- Push
the slide-rails into the slide-rail assemblies in the rack as far
as possible.
- Raise the server so that the
rear ends of the mounting brackets are aligned with the slide-rail
assemblies that are mounted in the rack.
- Insert the mounting brackets
into the slide-rails, and then push the server into the rack until
the mounting brackets encounter the slide-rail stops, approximately
30 cm (12 inches).
The server is now in the extended maintenance position.
1
Inserting mounting brackets into slide-rails
2
Slide-rail release tab (green)
3
Slide-rail lock
