For instructions, see Remove the PCIe Riser From PCIe Slots 3 and 4.
![]() | Caution - Whenever you remove a PCIe card, you should replace it with another PCIe card or a PCIe filler panel. Installing PCIe filler panels in vacant PCIe slots helps reduce the level of electromagnetic interference (EMI) emitted by the server. For instructions for installing PCIe filler panels, see Removing and Installing Server Filler Panels . |
