Remove a PCIe Card From PCIe
Slot 1 or 2
Note -
Either a standard PCIe card (CRU) or the optional PCIe NVMe switch card
can be installed in the PCIe riser for slot 1. The PCIe NVMe switch card is
a field replaceable unit (FRU) and, therefore, must be removed and replaced
only by authorized Oracle Services personnel. For instructions for servicing
the PCIe NVMe switch card, see
Servicing the Oracle PCIe NVMe Switch Card (FRU).
Note -
PCIe slot 1 is nonfunctional in single-processor systems.
- Remove
the
PCIe
riser from the server.
For instructions, see Remove a PCIe Riser From PCIe Slot 1 or 2.
- Remove the PCIe card from the
PCIe riser.
- Hold the riser in one
hand and use your other hand to carefully pull the PCIe card connector
out of the riser.
- Disconnect the rear bracket that
is attached to the PCIe card from the rear of the PCIe riser.
- Place the PCIe card on an antistatic
mat.
 | Caution - Whenever you remove
a PCIe card, you should replace it with another PCIe card or a PCIe
filler panel. Installing PCIe filler panels in vacant PCIe slots helps
reduce the level of electromagnetic interference (EMI) emitted by
the server. For instructions for installing a PCIe filler panel,
see Removing and Installing Server Filler Panels . |
