Install a PCIe Card in PCIe
Slot 1 or 2
Note - PCIe slot 1 is nonfunctional in single-processor
systems.
- Retrieve the PCIe card and riser you want to install.
- Insert the rear bracket that
is attached to the PCIe card into the PCIe riser.
- Hold the riser in one hand and
use your other hand to carefully insert the PCIe card connector
into the Riser.
- Install the PCIe riser into the
server.
For instructions, see Install a PCIe Riser Into PCIe Slot 1 or 2.
