Skip Navigation Links
Exit Print View
Netra SPARC T3-1 Server HTML Document Collection
search filter icon
search icon
Document Information
Using This Documentation
Product Notes
Related Documentation
Feedback
Support and Accessibility
Installation
Preparing for Installation
Installation Task Overview
Server Overview
Confirming Server Specifications
Shipping Kit Inventory List
Front Panel Components
Back Panel Components
Server Handling Precautions
ESD Precautions
Tools Needed for Installation
Optional Component Installation
Installing the Server
Rack Compatibility
Rack Cautions
Stabilize the Rack for Installation
Mounting the Server Into a 4-Post Rack
19‐Inch, 4‐Post Hardmount Rackmount Kit
Install the Server (19‐Inch, 4‐Post Hardmount Rackmount Kit)
19-Inch, 4-Post Sliding Rail Rackmount Kit
Install the Server (19-Inch, 4-Post Sliding Rail Rackmount Kit)
600-mm, 4‐Post Hardmount Rackmount Kit
Install the Server (600‐mm, 4‐Post Hardmount Rackmount Kit)
Mounting the Server Into a 2-Post Rack
23-Inch, 2‐Post Hardmount Rackmount Kit
Install the Server (23‐Inch, 2-Post Hardmount Rackmount Kit)
19-Inch, 2‐Post Hardmount Rackmount Kit
Install the Server (19‐Inch, 2-Post Hardmount Rackmount Kit)
19-Inch, 2-Post Rack Sliding Rail Rackmount Kit
Install a Server (19-Inch, 2-Post Sliding Rail Rackmount Kit)
Connecting the Server Cables
Cabling Requirements
Back Panel Connectors and Ports
Connect the SER MGT Cable
Connect the NET MGT Cable
Connect the Ethernet Network Cables
Connect Other Data Cables
Prepare the Power Cords
Assembling and Connecting DC Power Cords
Assemble the DC Input Power Cables
Connect the DC Input Power Cords to the Server
Powering On the Server for the First Time
Power On Task Overview
Oracle ILOM System Console Overview
Connect a Terminal or Emulator to the SER MGT Port
Power On the Server for the First Time
Oracle Solaris OS Configuration Parameters
Assigning a Static IP Address to the Service Processor
Identifying the Server Ports
USB Ports
Alarm Port
SER MGT Port
NET MGT Port
Gigabit-Ethernet Ports
Video Port
Administration
Understanding System Administration Resources
Oracle ILOM Overview
Platform-Specific ILOM Features
Oracle Solaris OS Overview
OpenBoot Overview
Oracle VM Server for SPARC Overview
Multipathing Software
Accessing the Server
Log In to ILOM
Log In to the System Console
Display the ok Prompt
Display the ILOM Prompt
Use a Local Graphics Monitor
ILOM Remote Console
Controlling the Server
Power On the Server
Power Off the Server
Reset the Server From the Oracle Solaris OS
Reset the Server From ILOM
Reset the SP to Default Values
Configuring Hardware RAID
Hardware RAID Support
Prepare to Use the FCode Utility
FCode Utility Commands
Create a Hardware RAID Volume
Locate Device Paths
Changing Server Identification Information
Change Customer FRU Data Information
Change System Identifier Information
Configuring Policy Settings
Specify Cooldown Mode
Restore Host Power State at Restart
Specify Host Power State at Restart
Disable or Re-Enable Power-On Delay
Specify Parallel Boot of the SP and Host
Configure Host Behavior With the Keyswitch State
Configuring Network Addresses
SP Network Address Options
Disable or Re-Enable Network Access to the SP
Display the DHCP Server IP Address
Display the Host MAC Address
Using an In-band Connection to the SP
Configuring Boot Mode
Boot Mode Overview
Configure the Host Boot Mode of Oracle VM Server for SPARC
Change the Host Boot Mode Behavior at Reset
Manage the Host Boot Mode Script
Display Host Boot Mode Expiration Date
Override OBP Settings to Reset the Server
Configuring Server Behavior at Restart
Specify Behavior When the Host Resets
Specify Behavior When the Host Stops Running
Set the Boot Timeout Interval
Specify Behavior at Boot Timeout
Specify Behavior if Restart Fails
Specify Maximum Restart Attempts
Configuring Devices
Unconfigure a Device Manually
Reconfigure a Device Manually
Monitoring the Server
Monitoring Faults
Enabling ASR
Display Server Components
Locate the Server
Updating the Firmware
Display the System Firmware Version
Update the Firmware
Display the OBP Version
Display the POST Version
Display the Hypervisor Version
Service
Identifying Components
Power Supply, Hard Drive, and Fan Module Locations
Top Cover, Filter Tray, and DVD Tray Locations
Motherboard, DIMMs, and PCI Board Locations
Detecting and Managing Faults
Diagnostics Overview
Diagnostics Process
Locating Components, Ports, and LEDs
Interpreting Diagnostic LEDs
Managing Faults (Oracle ILOM)
Interpreting Log Files and System Messages
Verifying Oracle VTS Installation
Managing Faults (POST)
Managing Faults (PSH)
Managing Components (ASR)
Preparing for Service
Safety Information
Find the Chassis Serial Number
Locate the Server
Component FRU Names and Service Links
Removing Power From the Server
Accessing Internal Components
Servicing the Air Filter
Remove the Air Filter
Install the Air Filter
Servicing Fan Modules
Fan Module LEDs
Locate a Faulty Fan Module
Remove a Fan Module
Install a Fan Module
Verify a Fan Module
Servicing Power Supplies
Power Supply LEDs
Locate a Faulty Power Supply
Remove a Power Supply
Install a Power Supply
Verify a Power Supply
Servicing Hard Drives
Hard Drive LEDs
Locate a Faulty Hard Drive
Remove a Hard Drive
Install a Hard Drive
Verify a Hard Drive
Servicing the Hard Drive Fan
Determine if the Hard Drive Fan Is Faulty
Remove the Hard Drive Fan
Install the Hard Drive Fan
Verify the Hard Drive Fan
Servicing the Hard Drive Backplane
Determine if the Hard Drive Backplane Is Faulty
Remove the Hard Drive Backplane
Install the Hard Drive Backplane
Verify the Hard Drive Backplane
Servicing the Power Distribution Board
Determine if the Power Distribution Board Is Faulty
Remove the Power Distribution Board
Install the Power Distribution Board
Verify the Power Distribution Board
Servicing the DVD Drive
Determine if the DVD Drive Is Faulty
Remove the DVD Drive
Install the DVD Drive
Verify the DVD Drive
Servicing the DVD Tray
Remove the DVD Tray
Install the DVD Tray
Servicing the LED Board
Determine if the LED Board Is Faulty
Remove the LED Board
Install the LED Board
Verify the LED Board
Servicing the Fan Board
Determine if the Fan Board Is Faulty
Remove the Fan Board
Install the Fan Board
Verify the Fan Board
Servicing the PCIe2 Mezzanine Board
Determine if the PCIe2 Mezzanine Board Is Faulty
Remove the PCIe2 Mezzanine Board
Install the PCIe2 Mezzanine Board
Verify the PCIe2 Mezzanine Board
Servicing the PCIe2 Riser Card
Locate a Faulty PCIe2 Riser Card
Remove a PCIe2 Riser Card
Install a PCIe2 Riser Card
Verify a PCIe2 Riser Card
Servicing PCIe2 Cards
Locate a Faulty PCIe2 Card
Remove a PCIe2 Card From the PCIe2 Mezzanine Board
Remove a PCIe2 Card From the PCIe2 Riser Card
Install a PCIe2 Card Into the PCIe2 Mezzanine Board
Install a PCIe2 Card Into the PCIe2 Riser Card
Install SAS Cable for Sun Storage 6 Gb SAS PCIe RAID HBA, Internal
Verify a PCIe2 Card
Servicing the Signal Interface Board
Determine if the Signal Interface Board Is Faulty
Remove the Signal Interface Board
Install the Signal Interface Board
Verify the Signal Interface Board
Servicing DIMMs
DIMM Configuration
DIMM LEDs
Locate a Faulty DIMM
Remove a DIMM
Install a DIMM
Verify a DIMM
Servicing the Battery
Determine if the Battery Is Faulty
Remove the Battery
Install the Battery
Verify the Battery
Servicing the SP
Determine if the SP Is Faulty
Remove the SP
Install the SP
Verify the SP
Servicing the ID PROM
Determine if the ID PROM Is Faulty
Remove the ID PROM
Install the ID PROM
Verify the ID PROM
Servicing the Motherboard
Determine if the Motherboard Is Faulty
Remove the Motherboard
Install the Motherboard
Verify the Motherboard
Install the Top Cover
Connect Power Cords to the Server
Power On the Server (Oracle ILOM)
Power On the Server (Power Button)
Glossary
Index
Note - The 23-inch, 2-post rackmount kit supports rack web thicknesses (the width of the rack post) of 76.20 mm (3 in.), 101.6 mm (4 in.), and 127 mm (5 in.).
  1. Read the Cautions for racks.
    See Rack Cautions.
  2. Using eight of the M5 x 7 SEM screws (four for each side bracket), secure the side brackets to the sides of the server.
    image:Figure showing how to secure the side brackets to the server.
  3. Lift the rail guides to the desired height in the rack and, using two screws each, secure both rail guides to the rack.
    The size of the screws varies, depending on your particular rack.
    image:Figure showing how to install the rail guides in the rack.
  4. Lift the server into the rack, and slide the server onto the rail guides.
    image:Figure showing how to secure the server in the two-post rack.
  5. Using two screws on each side, secure each side bracket on the server to the front of the rack.
  6. (Optional) If your environment contains especially high vibrations, install the rear plates to further secure the server to the rack.
    The rear plates attach to the rear of the post and to one of the three eyelets on each side bracket, depending on the thickness of the post.
    1. Using one M5 x 7 SEM screw for each rear plate, loosely install the screw in one of the three positions on the rear plate.
      The position varies depending on the thickness of the rail in the rack. For example, the following figure shows where you would install the screw for the middle rack position on the rear plate.
      image:Figure showing how to install a screw on the rear plate's shallowest rack position.
    2. Slide the rear plate in so that the screw slides into position into one of the eyelets.
      The screw head should be facing the rear of the server. The other side of the rear plate should be in front of the rack post.
      image:Figure showing how to install the rear plate to the side bracket.
    3. Tighten the screw to secure the rear plate to the eyelet on the side bracket.
    4. Using two screws, secure the other side of the rear plate to the back of the post.
      image:Figure showing how to secure the rear plate to the side bracket.
      The size of the screws varies, depending on your rack.
    5. Secure the rear plate on the other post.
      Repeat Step a through Step d.
Related Information
