This is a hot-service procedure that can be performed by a customer while the server is running.
![]() | Caution - Hazardous voltages are present. To reduce the risk of electric shock and danger to personal health, follow the instructions. |
![]() | Caution - If a power supply fails and you do not have a replacement available, to ensure proper airflow, leave the failed power supply installed in the server until you replace it with a new power supply. |
If necessary, release the CMA to access the power supplies. Do not allow the CMA to hang unsupported while it is unattached.
![]() | Caution - There is no “catch” mechanism on the power supply to prevent it from sliding completely out of the chassis. Use care when removing the power supply to prevent it from falling. |
