Go to main content
SPARC T8-2 Server Service Manual
Exit Print View
Updated: January 2022
Install a Power Supply
This is a hot-service procedure that can be performed by a customer while the server is running.
  1. If necessary, release the cable management arm to access the power supplies.
    See Release the CMA.
    Do not allow the CMA to hang unsupported while it is unattached.
  2. Align the power supply with the empty power supply chassis bay.
  3. Slide the power supply into the bay until it is fully seated.
  4. Move the release latch up to secure the power supply in place.
    image:Figure showing installing a power supply.
  5. Reconnect the power cord to the power supply.
  6. Verify power supply functionality.
    See Verify a Power Supply.
Related Information
