Go to main content
SPARC T8-2 Server Service Manual
Exit Print View
Updated: January 2022
Verify the SPM
  1. Verify that the SPM Status LED is illuminated green.
    The LED flashes green while the SPM initializes the Oracle ILOM firmware. See Interpreting LEDs for information about the status of the SPM LED.
  2. At the Oracle ILOM prompt, start the fault management shell.
    -> start /SP/faultmgmt/shell
    Are you sure you want to start /SP/faultmgmt/shell (y/n)? y
    faultmgmtsp>
  3. Type fmadm faulty to check for faults.
Related Information
