You can service the following components with the server in the service position:
Drives
Power supplies
Fans
Fan modules
Memory risers
DIMMs
PCIe cards
SPM card
Battery
eUSB drive
Although the CMA that is supplied with the server is hinged to accommodate extending the server, you should ensure that all cables and cords are capable of extending.
Squeeze the green slide release latches to release the slide rails.
See Release the CMA.
