Go to main content
SPARC T8-2 Server Service Manual
Exit Print View
Updated: January 2022
Return the Server to the Normal Operating Position
Caution
Caution  -  The chassis is heavy. To avoid personal injury, use two people to lift the server and set it in the rack.
  1. Release the slide rails from the fully extended position by pushing the release tabs on the side of each rail.
    image:Figure showing release tabs on the server rails.
  2. While pushing on the release tabs, slowly push the server into the rack.
    Ensure that the cables do not get in the way.
  3. Reconnect the cables to the rear of the server.
    If the CMA is in the way, disconnect the left CMA release and swing the CMA open. See Release the CMA.
  4. Reconnect the CMA.
    Swing the CMA closed and latch it to the left rack rail. See Server Installation for more detail about attaching the CMA.
  5. Attach the power cords to the server.
    See Attach Power Cords.
Related Information
