Go to main content
SPARC T8-2 Server Service Manual
Exit Print View
Updated: January 2022
Determine Which Power Supply Is Faulty
  • Check if the following LEDs are lit when a power supply fault is detected.
    • Service Required LEDs on the front and rear panels.
    • Rear PS Fault LED on the front panel.
    • Service Required LED on the faulted power supply.
Related Information
