This is a cold-service procedure that must be performed by qualified service personnel. Power down the server completely before performing this procedure.
![]() | Caution - This procedure requires that you handle components that are sensitive to ESD which can cause server components to fail. |
See Prevent ESD Damage.
![]() | Caution - When connecting the ribbon cable to the motherboard, take care to center the cable on the connector before inserting the cable. |
See Remove a Fan Module.
See Returning the Server to Operation.
