Go to main content
SPARC T8-2 Server Service Manual
Exit Print View
Updated: January 2022
Find the Server Serial Number
You need the serial number of the server's chassis to obtain technical support for the server.
Note -  When a PS backplane, fan board, or drive backplane is replaced, the chassis serial number and part number might need to be programmed into the new component. This must be done in a special service mode by trained service personnel.
  • Locate the serial number using one of the following methods:
    • Read the serial number from a sticker located on the front of the server or another sticker on the side of the server.
    • At the Oracle ILOM prompt type:
      -> show /System
      /System
         Targets:
      In the output look for a line under Properties that identifies the product serial number. For example:
      serial_number = BKL1026F8F
Related Information
