A metal air baffle is attached to the rear inside surface of the top cover. When you place the top cover on the server, ensure that the air baffle does not catch on anything inside the server.
Set the cover down so that it is about 1 inch (2.5 cm) forward of the rear of the server.
Caution - Failure to completely secure the top cover may cause the server to malfunction. |
