These topics provide information on the Giant Domain configuration for the Full Rack:
One domain is set up on each SPARC T5-8 server in this configuration, taking up 100% of the server. Therefore, 100% of the CPU and memory resources are allocated to this single domain on each server (all eight sockets).
Two out of the four 1-GbE host management ports are part of one IPMP group for this domain:
NET0
NET3
All eight PCI root complex pairs, and therefore eight 10-GbE NICs, are associated with the logical domain on the server in this configuration. However, only two of the eight 10-GbE NICs are used with this domain. One port is used on each dual-ported 10-GbE NIC. The two ports on the two separate 10-GbE NICs would be part of one IPMP group. One port from the dual-ported 10-GbE NICs is connected to the 10-GbE network in this case, with the remaining unused ports and 10-GbE NICs unconnected.
The following 10-GbE NICs and ports are used for connection to the client access network for this configuration:
PCIe slot 1, port 0 (active)
PCIe slot 14, port 1 (standby)
A single data address is used to access these two physical ports. That data address allows traffic to continue flowing to the ports in the IPMP group, even if one of the two 10-GbE NICs fail.
The connections to the InfiniBand network vary, depending on the type of domain:
Database Domain:
Storage private network: Connections through P1 (active) on the InfiniBand HCA associated with the first CPU in the first processor module (PM0) in the domain and P0 (standby) on the InfiniBand HCA associated with the last CPU in the last processor module (PM3) in the domain.
So, for a Giant Domain in a Full Rack, these connections would be through P1 on the InfiniBand HCA installed in slot 3 (active) and P0 on the InfiniBand HCA installed in slot 16 (standby).
Exadata private network: Connections through P0 (active) and P1 (standby) on all InfiniBand HCAs associated with the domain.
So, for a Giant Domain in a Full Rack, connections will be made through all eight InfiniBand HCAs, with P0 on each as the active connection and P1 on each as the standby connection.
Application Domain:
Oracle Solaris Cluster private network: Connections through P0 (active) on the InfiniBand HCA associated with the first CPU in the second processor module (PM1) in the domain and P1 (standby) on the InfiniBand HCA associated with the first CPU in the third processor module (PM2) in the domain.
So, for a Giant Domain in a Full Rack, these connections would be through P0 on the InfiniBand HCA installed in slot 4 (active) and P1 on the InfiniBand HCA installed in slot 7 (standby).
