Perform this procedure for each Exadata Storage Server before you power them off. For more information on this task, see the Exadata documentation at:
http://wd0338.oracle.com/archive/cd_ns/E13877_01/doc/doc.112/e13874/maintenance.htm#CEGBHCJG
CellCLI > LIST GRIDDISK ATTRIBUTES name WHERE asmdeactivationoutcome != 'Yes'
If any grid disks are returned, then it is not safe to take Exadata Storage Server offline, because proper Oracle ASM disk group redundancy will not be maintained. Taking Exadata Storage Server offline when one or more grid disks are in this state will cause Oracle ASM to dismount the affected disk group, causing the databases to shut down abruptly.
CellCLI> ALTER GRIDDISK ALL INACTIVE
This command completes after all disks are inactive and offline.
CellCLI> LIST GRIDDISK WHERE STATUS != 'inactive'
If all grid disks are INACTIVE, then Exadata Storage Server can be shut down without affecting database availability.
