Adjust the Leveling Feet
There are leveling feet at the four corners of the rack.
Locate the 12-mm wrench inside the rack.
Use the wrench to lower the leveling feet to the floor.
When lowered correctly, the four leveling feet should support the full
weight of the rack.
