SuperCluster
Tools
Use one of these tables according to the version of SuperCluster
software. Use the tables to see what tools are available.
To identify your version, see Identify the Version of SuperCluster Software.
Note - The tables do not provide a complete list of tools for
SuperCluster. Instead, the tables list the tools are covered in
subsequent sections and provides information on what is available
based on specific version of SuperCluster software.
Table 20 SuperCluster v1.x Tools
ssctuner |
A set of scripts and configuration files
that run on SuperCluster Oracle Solaris 10 and Oracle Solaris 11
global zones to monitor and tune various parameters. |
osc-setcoremem |
Enables you to change how CPU and memory
resources are allocated across domains. |
Table 21 SuperCluster v2.x Tools
Oracle I/O Domain Creation tool |
Enables you to create I/O domains on demand,
assigning CPU, memory and I/O resources of your choice. |
Refer to the Oracle
I/O Domain Administration Guide. |
osc-setcoremem |
resources are allocated across domains. The tool automatically assigns the
appropriate amount of memory to each domain based on how you allocated CPU
resources, ensuring optimal performance by minimizing NUMA effects. |
ssctuner |
