All domains
are dedicated domains
Plan how the CPU and memory resources
are allocated to the domains. |
Reallocate all of the resources across
domains at the socket or core level (a reboot is required if primary
domain resources are changed). |
Remove (park) resources from dedicated domains
for licensing purposes.
Note - Parked resources are not available for use by any domains. |
Revert to a previous resource configuration. |
Remove a CPU/memory configuration. |
Mixed domains – some are
dedicated, some are Root Domains
Activities
you can only perform at initial installation, before any I/O Domains
are created: |
Activities
you can perform anytime: |
Refer to the I/O
Domain Administration Guide. |
