Go to main content
Oracle® SuperCluster T5-8 Owner's Guide
Exit Print View
Updated: May 2016
Configuring ASR on the SPARC T5-8 Servers (Oracle Solaris 11)
Note -  Do not attempt to copy and paste commands that span across multiple lines from this section. Manually type commands that span across multiple lines to ensure the commands are typed properly.
Oracle Solaris 11 includes the ability to send ASR fault events and telemetry to Oracle using xml over HTTP to the ASR Manager.
To enable this capability use the asr enable_http_receiver command on the ASR Manager. Select a port for the HTTP receiver that is appropriate for your network environment and does not conflict with other network services.
Perform the following tasks:
