Go to main content
Oracle® SuperCluster T5-8 Owner's Guide
Exit Print View
Updated: May 2016
Drop an Exadata Storage Server
  1. From Oracle ASM, drop the Oracle ASM disks on the physical disk using the following command:
    ALTER DISKGROUP diskgroup-name DROP DISK asm-disk-name
    To ensure correct redundancy level in Oracle ASM, wait for the rebalance to complete before proceeding.
  2. Remove the IP address entry from the cellip.ora file on each database server that accesses the Exadata Storage Server.
  3. From Exadata Storage Server, drop the grid disks, cell disks, and cell on the physical disk using the following command:
    DROP CELLDISK celldisk-on-this-lun FORCE
  4. Shut down all services on the Exadata Storage Server.
  5. Power down the cell.
    Tip  - Refer to Shut Down or Reboot an Exadata Storage Server for additional information.
