Use this procedure to shut down the system under normal circumstances.
Shut down Oracle Solaris Cluster:
# /usr/cluster/bin/cluster shutdown -g 0 -y
If Ops Center is running, shut down the enterprise controller:
# /opt/SUNWxvmoc/bin/ecadm stop
For HA environments use this command:
# /opt/SUNWxvmoc/bin/ecadm ha-stop-no-relocate
Shut down the database using one of these methods:
http://docs.oracle.com/cd/B28359_01/server.111/b28310/start003.htm
Gracefully shut down each SPARC T5-8 server:
# init 0
Gracefully shut down the ZFS Storage Controller.
Log in to the browser interface and click the power icon on the left side of the top pane.
Power off the switches, and the entire rack, by turning off the circuit breakers.
To power the system back on, see Power On the System.
