Use this procedure to revert a compute node to a previous CPU/Memory configuration. You must perform this procedure on each member in a cluster. The tool does not automatically propagate changes to every cluster member.
# ldm list-config factory-default V_B4_4_1_20140804141204 after_install_backup CM_2S1T_1S512G_3S1536G_082020141354 CM_2S1T_1S512G_3S1536G_082120140256 CM_1S512G_1S512G_4S2T_082120140321 [next poweron]
For details about SP configuration files see View the SP Configuration.
# ldm set-config CM_2S1T_1S512G_3S1536G_082020141354
# #. -> cd /SP -> stop /SYS Are you sure you want to stop /SYS (y/n) ? y Stopping /SYS -> start /SYS Are you sure you want to start /SYS (y/n) ? y Starting /SYS
