If optional Fibre Channel PCIe cards are purchased for SuperCluster M8 or SuperCluster M7, use this procedure to install the cards.
Each CMIOU in the compute node has three slots, each of which can hold one PCIe hot-plug card carrier. Each of these carriers contains a single low-profile PCIe card. For the location of the PCIe cards, refer to the Oracle SuperCluster M8 and SuperCluster M7 Overview Guide.
Additional installation details are available in these documents:
The documentation provided with the PCIe card.
The SPARC M7 Series Servers Service Manual. See Hardware Installation Documents.
The card is correctly seated only when the notch at the top of the card bracket fits around a guide post on the carrier.
If the PCIe card includes a mounting screw, do not use the mounting screw. The carrier does not accept mounting screws.
The green latch clicks, locking the card in the carrier.
If the carrier slides correctly into the slot, you feel a slight resistance as the carrier starts to seat in the connector.
![]() | Caution - Do not push the extraction lever while you insert the carrier into the slot. The carrier can enter at an angle and damage the connectors. |
