| Skip Navigation Links | |
| Exit Print View | |
Sun Network QDR InfiniBand Gateway Switch HTML Document Collection for Firmware Version 2.1 |
Preparing to Install the Gateway
Assemble the Optical Fiber Data Cables
Install the Gateway in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Gateway
Configuring Secure Fabric Management
Administering Gateway Resources
Installing Gateway Supportive Software (Linux)
Creating VNICs Under Gateway Manual Mode (Linux)
Creating VNICs Under Host Manual Mode (Linux)
Creating Virtual IO Adapters (Oracle Solaris)
Controlling Gateway Ports and Parameters
Understanding Oracle ILOM on the Gateway
Upgrading the Gateway Firmware Through Oracle ILOM (CLI)
Upgrade the Gateway Firmware (Web)
Display Gateway Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Determine If the Battery Is Faulty
Remove the Gateway From the Rack
Transfers a file from a remote location to update a target.
load [-force][-o verbose][-script]-source URI[target]
where:
URI is the uniform resource indicator.
target is the target and path to act upon.
This Oracle ILOM command transfers information in a file from a remote location specified by the URI to update a target. If no target is specified, the current target is affected. Your user must have administrator (a) privileges to use this command.
This table describes the options to the load command and their purposes:
This example shows how to load a custom certificate file, server.pem, to the /SP/services/https/ssl/custom_cert target from the host at IP address 123.45.67.89 using the TFTP protocol with the load command.
-> load -source tftp://123.45.67.89/server.pem /SP/services/https/ssl/custom_cert Load successful. ->
