| Skip Navigation Links | |
| Exit Print View | |
Sun Network QDR InfiniBand Gateway Switch HTML Document Collection for Firmware Version 2.1 |
Preparing to Install the Gateway
Assemble the Optical Fiber Data Cables
Install the Gateway in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Gateway
Configuring Secure Fabric Management
Administering Gateway Resources
Installing Gateway Supportive Software (Linux)
Creating VNICs Under Gateway Manual Mode (Linux)
Creating VNICs Under Host Manual Mode (Linux)
Creating Virtual IO Adapters (Oracle Solaris)
Controlling Gateway Ports and Parameters
Understanding Oracle ILOM on the Gateway
Upgrading the Gateway Firmware Through Oracle ILOM (CLI)
Upgrade the Gateway Firmware (Web)
Display Gateway Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Determine If the Battery Is Faulty
Remove the Gateway From the Rack
Displays InfiniBand switch nodes in the topology.
ibswitches [-h][topology|-C ca_name][-P ca_port][-t timeout]
where:
topology is the topology file.
ca_name is the channel adapter name.
ca_port is the channel adapter port.
timeout is the timeout in milliseconds.
This InfiniBand command is a script the discovers the InfiniBand fabric topology or uses an existing topology file to extract the switch nodes.
The ibswitches command is available from the /SYS/Switch_Diag, /SYS/Gateway_Mgmt, and /SYS/Fabric_Mgmt Linux shell targets of the Oracle ILOM CLI interface.
This table describes the options to the ibswitches command and their purposes.
This example shows how to display the switch GUIDs with the ibswitches command.
Note - The output for your InfiniBand fabric will greatly differ from that in the example.
FabMan@gateway_name->ibswitches Switch : 0x00212856cfe2c0a0 ports 36 "SUN IB QDR GW switch mnm34-98" enhanced port 0 lid 6 lmc 0 FabMan@gateway_name->
ibswitches man page
